Hi all
Due to the limitations of the server, we will carry out the migration of jira in the near future. According to the guidance of the official document, we have installed the new jira service in the new server, replaced the main directory data, and updated the relevant configuration files
Our service and database are deployed separately, backed up daily with the mysqldump command, and we restore to a new database with the backup sql file and assign the new database to the new server. The jira service started normally, but we were unable to create an issue
When we create an issue or query with a jql statement, an error message is displayed
And the left column of the project is empty
We have performed the refactoring of the index operation, but this does not solve the problem, what is the cause of the problem
Here's what I found for problems with XSRF errors. You may have to contact Atlassian Support about this problem.
https://community.atlassian.com/t5/Jira-questions/XSRF-check-failed/qaq-p/999637
This Community post references this KB https://confluence.atlassian.com/jirakb/creating-project-throws-error-creating-project-xsrf-check-failed-397083076.html
True, support for Jira Server ended in February. so contacting Atlassian Support is not an option.
thank you for your help
I have found the cause of this problem, which is caused by our different tomcat configurations. I modified the server.xml file, and it is now back to normal, but we have encountered other problems, and this problem will be closed
