Hi
Actually I am try to change the original estimate of issue depend upon the value enter in another custom field number from 1 to 100.
so for example let suppose we have original estimate 10h when we enter 60 in another custom field I will change 10H to 60 percentage like 6H ,I am using Jira automation here is the following step I did
But it gives error
(Specify a valid value for Original estimate (timetracking_originalestimate), Specify a valid value for Original estimate (timetracking))
kindly help me with this.
Hi @Umar Maroof
The correct smart value would be:
{{issue.fields.timetracking.originalEstimateSeconds.multiply(issue.fields.customfield_10185).divide(100)}}
But to be fairly honest, I'm quite puzzled of how and IF your rule is going to work properly.
Just making sure that you have thought of every aspect of your rule.
@Alex Koxaras -Relational- is there is any idea how I increase that ? But increasing Coustom field value?
@Umar Maroof the first thing you want to do is to write down all your requirements about how this rule would work. And cover all aspects of it. When you have this, then I might be able to provide a better answer and a possible solution.
@Alex Koxaras -Relational- what I am trying to do let suppose we have an issue which is estimated 10H and we have time period for a issue lets suppose 7 days so this issue is no complete in 7 days the work of this issue is done only 60% so the user only enter 60 on that custom field so the original estimate of that issue will change to 6H and when he enter 60 the new issue is created automatically and its original estimate will be the difference of the original estimate before we enter value like 10H and the original estimate after we enter value i.e. 6H so the automatically created issue then having the original estimate 4H that what I am trying to do
Can you please help me for filling the original estimate for automatic issue that we will be difference of he original estimate before we enter the value of custom field for the pervious issue and the original estimate of pervious issue after enter value ...I.e. in example will be 4H
@Alex Koxaras -Relational- Also the smart value you give me above its not working exactly like some time rules run for many times some time 2 time and the values are very different in original estimate
I enter 8m first original estimate then I enter 50 in custom field it changes to 4h
then I enter 10h and enter 50 in custom field it changes to 7w 2d 4h
@Umar Maroof the smart value I gave you works exactly as you specified on your question. No more, no less. Saying it's not working correct, while not giving any details of how you use it in your rule and what are the expected vs the actual results, doesn't help me in providing additional help :/
@Alex Koxaras -Relational- I write the details above also I edit my comment can you please help me with this
The steps you are referring to are the following:
So basically what you are trying to achieve is to create a new issue when the user will enter a number on a numeric field in jira and on that new issue the original estimate will be the difference between the "old's" issue original estimate, minus the "old's" issue original estimate times the numeric field (divided by 100).
Yes, you could do that, but why you want to mess with the original estimate? The original estimate as a field is there to simply give you information about the actual estimation of the time you thought this work will need. And you need this value in order to do later a retrospective. Changing this value will manipulate your data and you will lose the ability to measure effectively your team's capacity and capability of estimating issues.
@Umar Maroof concerning your last comment
@Alex Koxaras _Relational_ I write the details above also I edit my comment can you please help me with this
The smart value I provided works just fine. I've tested it on my instance with both your examples and it yields correct results:
@Alex Koxaras -Relational- yes you are right I am exactly trying to do that the steps you explain in above comment.
this is because we have reports for every weeks so some tasks are unfinished so this method is for that tasks so new issue will create and that difference of original estimate will consider in that issue
can you help me with that how can I achieve that
@Umar Maroof I could guide you in the right direction, but you still haven't answered me or replied to the previous comments I made about:
So to answer your question and help you/guide you:
Valuable links are:
You should study the above and learn how to create rules and to debug them in order to find what's wrong. They will help you achieve your goal!
