Hi Guys,
I need to change the issue key of Jira soft project which contains more the 1000 issue's.
we are using JIRA Soft 7.0.5 version and PostGrase SQL 9.5 Version can you tell me how to change this so that it will be very helpfull for me.
Hi My issue is i need to change the project key and it should effect in the attachment key also but attachments taking old project key that is disturbing the plugin we build in our organisation.
Could you provide more details of your distribution plugin?
Or other way is change on DB for attachments linkage info as well
