Hello team
I need to rank my issues in backlog with priority , so i followed this documentation below from atlassian site .
Enabling ranking
Go to your board, then select more (•••) > Board settings.
Note that only the administrator of a board (or a person with the 'Jira Administrators' global permission) can configure a board. Click the Add Rank button. This will append the following to your filter's query, withORDER BY Rank ASC
as the default setting:ORDER BY Rank ASC
You can also rank issues by other issue properties — for example,priority
orissuetype
.ORDER BY priority DESC
ORDER BY issuetype DESC
Based on this documentation i changed my board filter (ORDER BY priority DESC) i t works fine , my issues now are organised with priority , but the problem is i can not create a sprint error = the board must be ordered by rank in order to add a sprint . So if i click to add rank in board it will delete (ORDER BY priority DESC) and adding Rank ASC .
Can someone help me please ?
Thank you
Hi Karim - The short answer is your are not going to be able to have it both ways on a single board.
My suggestion would be to create a second board for your Backlog ranking by priority. And then have your regular board with ORDER BY Rank for adding/managing your sprints.
Hello @John Funk
Thank you for your quick response .
But hear if i create the second board and organize my issues using priority , i will be not able to create sprint . That's it ?
Or i don't understand will ?
This functionality work in cloud .
Thank you
Regards
You would not be able to create the sprint in the second board,no. You would have to rearrange the issues manually on the first board based on the order you have them in the priority board. And then create the sprint with the ranking board.
Just fyi this functionality is available in jira cloud .
Cheers
