copy system field due to custom field while creating the current issue
Manideep Sadhu March 15, 2018
i need to copy the system filed value to the custom filed while creating the issue, could any one post the code to get the value from system field
Aidan Derossett [Adaptavist]
March 16, 2018
Hey there Manideep!
Usually you can get the value of a system field simply by calling methods directly on the Issue object. For instance, if you're dealing with a MutableIssue object, you have a ton of getter methods at your disposal:
issue.summary //gets you the summary
issue.description //gets you the description
//etc...
But it really depends on the context. What is your use-case? Why are you trying to get the system field values and where are you wanting to get them (i.e. in a post-function, behaviour, listener, etc...)?
Manideep Sadhu March 18, 2018
Hi Aidan Derossett [Adaptavist]
 Thanks for reply,
As i was new to this scriptrunner.this was one of our requirement
I want to get them in behaviour , i tried with issue .summary showing null but i was failed to get the issue object could you suggest me the way how to get the issue object
I you post the complete code that would help me a lot.
March 22, 2018
Hey again,
For Behaviours the process is a little bit different. If you'd simply like to access a field that's on the form (like the create issue dialog or something), then we have a whole bunch of built in methods that you can use to do so: getFieldById, getFieldByName, etc... And with those you can get the summary field:
def summary = getFieldById("summary")
def summaryVal = summary.value
//etc...
 But, if you need the issue object itself, we also have built-in variables that you can use, like "underlyingIssue." That variable represents the current issue, so it's an Issue object and you could treat it as such, doing something like:
def summary = underlyingIssue.summary
If you want to know more about Behaviours or need to look at some examples, we have some great resources in our documentation
Does that answer your question? :D
Best,
Aidan
Manideep Sadhu March 25, 2018
Hi Aidan Derossett [Adaptavist],
Thanks very very much, its works fine.
I had one more doubt this works when we are creating the task, but what about the already created ones. Do i need to write post functions , if we write post function how can we add custom fields programatically
Manideep
