criteria for releasing versions.
jeroen.wilmes
July 29, 2024
We do use Releases in JIRA for releasing versions.
We do NOT use resolutions.
Criteria for Releasing versions is that all issues need to be in status done AND resolution may not be "unresolved".
Is it possible to change the criteria for releasing issues in Jira Cloud?
As we do not use resolutions (status is enough) all issues have the default value "unresolved" and for that reason we cannot release a version, other than " accepting all unresolved issues" which is not a nice way to work.
2 accepted
Dave Mathijs
Hi @jeroen.wilmes You may not use Resolutions as criterium for your releases, but the Resolution field is essential for Jira to determine whether an issue is open or resolved (i.e. done)
Why don't your set an automatic resolution (f.e. Done) for status 'Done' via a post function in your workflow?
jeroen.wilmes
July 30, 2024
Thanks Dave,
I agree on this. I had a closer look on how we organized the workflows and I discovered that we dit not set it up consequently.
Either we should use a screen for giving a resolution value and make that field required via the validator for entering the status.
or
We should give the set the resolution field to "resolve" by creating the post function entering the status done.  (and don't forget to clear that field if we enable issue to be re-opened again.
Like Dave Mathijs likes this
John Funk
Hi Jeroen - Welcome to the Atlassian Community!
No, you will not be able to change the criteria. Is there a reason you do not want to populate the Resolution field when completing an issue?
jeroen.wilmes
July 30, 2024
Thanks John, see above.
Like John Funk likes this
John Funk
You are welcome.
