custom field in jira automation
Anton Sivolap August 16, 2021
I need to check if my cistom field "customfield_19700" is emply and than to add some slacg group to that field.
Can you help me with 1st operation to find that fild
and thaen how to write jql to fill this field with text
John Funk
Hi Anton - Welcome to the Atlassian Community!
Why not just use a regular Condition for Issue Fields Condition? Select your field in the drop down and use Is Empty for the condition.
I can`t see in drop this field.
John Funk
What type of field is it?
This is field when user make ticket, and I need to chek if he fill itCreate Issue - Jira - Google Chrome 2021-08-16 16.30.02.png
John Funk
Ah, it's a grouper picker type field, which Automation can't handle right now.
In the Advanced Compare, change the condition to: does not match regular expression
Then in the regular expression field type:
(^null$|^$)
Anton Sivolap August 18, 2021
ok. I understand first part. But now I need to write action To fill some text in this field - need to add some slack group to this field. I try
"customfield_19700": "jira-promo user"
but didn`t work this sintaksis
John Funk
You are going to need the account ID of the user. Something like
"customfield_19700": {{issue.Issue Watchers. accountId}}
