Hi @sgole you need to remove it from Edit screen. Then you need to preapre new transition called for example "Edit Work Order", set new screen with "Work order" field to it and let the user to adjust the value this way.
To edit Edit screen you have to:
More about screens can be found here:
Hello @Martin Bayer _MoroSystems_ s_r_o__ ,
are you suggesting to split Edit Screen of View screen, isn't it?
Best regards.
But with this solution, the "Work order" field isn't appear in the View screen so, if the user want to check it, will be somethings needed..
Or edit screen or add in the screen with some automation for example ScriptField or Fragment.
Isn't it?
Best regards.
No, you need to have two screens for view/edit purposes
I hope it will help :)
Hi @Martin Bayer _MoroSystems_ s_r_o__ ,
it helps but the behaviour is the oposite in my case.
I've resolved with an scriptField in View Screen (is read only) and "Work order" field in edit screen (to be edited).
Thanks for your support.
