def issue = event.issue as issue in groovy. A error saying event is not declared for class is coming. I dont know what the problem is. I am trying to get the current issue key which is created after create issue event.
You need to tag your question with scriptrunner if you expect the vendor to help.
You're trying to cast 'event.issue' as an Issue but you haven't imported the Issue class. So the error is obvious.
Add
to the top of your script and it will no longer cause an issue.
Hello @Meena Sabnivisu and @Steven F Behnke ,
I am facing the same error even though I have imported Issue Class. Please let me know how to fix it. script runner version: 6.5.0. Jira version: 8.5.0
