difference b/w default issues ? why we use default issues types ? where we use default issue types?
please give me detailed information.
Actually, where and when you use them is up to you. What matches your process? If you don't want to use "tasks", don't use them.
Assuming you have Jira Software, then you have three groups of types to think about:
Hi Srinivas
Default issue types are the ones that comes bundled with the JIRA installation. Atlassian has setup the default issue types as the standards that are specific to the product installs.
Most probably you would want to start with those issue types and then extend with custom ones as per your requirements.
Hi Fazila
Thank you for your response.
yeah the are 7 default issue types , but my equation is where we use those default issue types ? When we use those default issue types ? And difference b/w those default issue types.. I need some detailed clarification.
thank you
Ah.. i hope the information in https://confluence.atlassian.com/adminjiraserver/issue-fields-and-statuses-938847116.html helps you on that..
