Hello everyone,
What is the difference between linking a screen scheme to an issue type and adding a screen to the Create transition of a workflow?
Regards.
You don't associate screens with the create transition.
Hello Nic,
The "CREATE" transition gives me the option of establishing a screen, which is why I have doubts about whether or not it works.
Ah, I thought they'd removed that.
The screen on the create transition is irrelevant, it is not used.
