do we need to write a behaviour script for that or validator will work?
Saudamini Deshmukh August 26, 2021
There are two custom fields named "KA ID" & "Potential Knowledge article" having dropdown of(Yes/No).
for escalation issue type in workflow while closing the issue the KA ID field should be mandatory only when the Potential Knowledge article is set to yes and should not be mandatory when it sets to No.
Nic Brough -Adaptavist-
August 26, 2021
Either will be able to do it.
Have a look in the https://library.adaptavist.com for examples of both approaches.
Hey Nic!! Thank You so much for your response. I will look in to it
