hello,
I have some "standard projects" types that are always running in the company, example : design new product, import Items from China, etc. each project type have same phasis :start, validations, attached documents, comments, due dates, etc.
I ask if Jira Core is the product for that ?
for example : in "design new product" project, can I setup with Jira Core
5 status (on design, waiting validation, in revue, validated, prototype done, new producte created),
3 transitions : validated, rejected,
etc.
is it correct or there is an other product for that.
thank you.
zied.
Yes, this is a good use for Core!
