download problem
Döndü Türkmen August 9, 2021
I am getting an error like this. How can i solved this problem. Can you help me?
Dirk Ronsmans
Yes, but I don't know how to access and edit jira home directory? Can you explain?
Dirk Ronsmans
Sure, it is a bit of a lengthy procedure to type out but it's is described in full at the links in my documentation link.
For example you could change your home directory using the following instructions:
https://confluence.atlassian.com/adminjiraserver073/setting-your-jira-application-home-directory-861253889.html
Like # people like this
Nic Brough -Adaptavist-
August 9, 2021
You must not nest one part of Jira within another.  It's fine to do something like:
  • Install: /opt/jira-install
  • Home: /opt/jira-data
but you must never nest the two like:
  • Home: /opt/jira-install/jira-data
or
  • Install: /opt/jira-data/jira-install
