enable roadmap product and initiatives
Jean-Michel.Van August 7, 2024
Our company has JIRA premium. How can I enable roadmap product, initiative, and hierarchy function?
Svitlana Samotis (Reliex)
August 7, 2024
Hi @Jean-Michel.Van
You can start by navigating to the Jira Settings -> Products page. There you’ll find the Plans section on the left-hand side:
Within the Plans section, you can set permissions as well as configure the hierarchy. Specifically, under the Hierarchy configuration tab, you can set up your hierarchy and initiatives.
You can refer to this guide for help: Configure Custom Hierarchy Levels in Advanced Roadmaps.
Regards, Svitlana
Jean-Michel.Van August 23, 2024
Hi Svitlana,
Thanks but we cannot link a story/task to an Initiative or Theme directly right?
My objective is to build an OKR (Product Goals) tree and account for all the tasks linked to the top Product Goals.
How can I do this?
Best,
JM
August 26, 2024
Hi Jean-Michel,
You would need to have en epic level between them but other than that you can build and track those relations:
Svitlana
Jean-Michel.Van August 26, 2024
1- So I need an Epic in between.
2- What about Goal?  I cannot link Goal to a Task either  so how can I track all activities linked to a Top OKR?
how do your other customers do it as best practice?
August 27, 2024
There are add-ons on Atlassian Marketplace specifically for OKR tracking. I would suggest checking out: OKR Board for Jira by Oboard
Svitlana
