hi ,
after trying to insert my Jira link into the query i get this error:
i made sure i can download it using the same link using webpage.
can you direct me to what should i do in this case?
it exist , as i stated when i use the same link in my browser, they file is getting downloaded with no issue.
@ronny gordonI suspect that something is blocking connection so in the excel spreadsheet,
try File > options > Trust Center > Trust Center Settings > External Content
under security settings for data connection choose enable all data connection
and see whether this helps.
Best!
didnt help :( thanks. i'll try to go snoop around the project permissions.
