filed "Issue Links" missing in exported issues csv
Gunnar Wagner October 31, 2023
I want to import issues (task, story, bug, sub-task) from csv and try to use an exporteed csv as template as per https://community.atlassian.com/t5/Jira-questions/How-to-export-Jira-issues-to-CSV/qaq-p/175115).
I select all fields during the export but the "Issue Links", which I am using extensevely does not exists in the csv. What Am I doing wrong?
Laurie Sciutti
Hello @Gunnar Wagner ~ these should have the header of "Inward issue link" and  "Outward issue link" in your csv.  HTH
true. Don't know how I did not notice those. thx
Like Laurie Sciutti likes this
