Hi @Demenagas Dimitrios ,
Please check out this documentation: https://confluence.atlassian.com/jirakb/how-to-deactivate-comments-for-closed-issues-648217599.html
That should help you.
thank for your reply.
I wasn't very clear in my question.
I am using Exocet to synchronize issues and when I add a comment to my ticket in service desk then the system will add the comment on any jira issue.
What I want is : when the jira issue is closed the comment do not be added.
Hello @Demenagas Dimitrios ,
Have you tried to add a condition on the status attribute in the target/source request JQL (in the Exocet configuration)?
... AND status != Closed ...
Nicolas
@Demenagas Dimitrios digging on the topic, and testing it on v7.9, if you use:
jira.permission.comment.denied=true
that should make the job.
I would also recommend to use it in conjunction with:
jira.issue.editable=false
to avoid any change on the closed issue.
Try and let me know.
Btw, @Nicolas Simon would be a nice solution as well +1
PS: was inspired by https://www.j-tricks.com/tutorials/permissions-based-on-workflow-status
