how can i return and parse json values in script console
ali kemal cem özdemir April 24, 2018
Hey guys, i want to create a issue on remote jira with jira  rest api. Codes in below, it's working great.  But i want to return json values, because when the issue created, json returns with issue id.  I need this id.
values:
{"id":"117216","key":"TEKFENEHM-1672","self":""}
How can i get id. Can you help me please. Best regards.
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.ComponentManager
import groovy.json.StreamingJsonBuilder
def baseURL = "full_url/rest/api/2/issue/";
def authString = "username:password".getBytes().encodeBase64().toString();
def body_req = [
           "fields": [
            "project":
                "key": "TEKFENEHM"
            "summary": "REST API TEST example",
            "issuetype": [
                "name": "Question"
URL url = new URL(baseURL);
HttpURLConnection connection=(HttpURLConnection)url.openConnection();
connection.setRequestProperty( "Authorization", "Basic ${authString}" );
connection.requestMethod = "POST";
connection.doOutput = true;
connection.setRequestProperty("Content-Type", "application/json;charset=UTF-8");
connection.outputStream.withWriter("UTF-8") { new StreamingJsonBuilder(it, body_req) }
connection.connect();
Deleted user April 25, 2018
Hi Ali,
I'm having now the same issue. I would like to use the response of my POST, because i need the id too.
If you find the solution inform at this question, please!
I will be looking for the solution too.
ali kemal cem özdemir April 26, 2018
Hey man, yes i found the solution.
I used the getInputStream method.
Here is the some documantations about this method.
https://docs.oracle.com/javase/7/docs/api/java/net/URLConnection.html#getInputStream()
and here is the my codes.
            InputStream response = connection.getInputStream();
            String response_string =response.getText()
            def jsonSlurper = new JsonSlurper()
            def json_object = jsonSlurper.parseText(response_string)
            assert json_object instanceof Map
      return json_object.id
 If you have a problem please notify me. Regards.
Like # people like this
Pradeep A
HI
 I want to create an issue from Jira and get the issue details through the API. I need to receive the issue details, So that I can work with my third party app. Hope you can Understand my scenario. Please revert back if you have any solutions.
