Hi Team
Please help me for reindexing in jira .
how can we start jira reindexing with steps and please tell us how can we monitor reindex status in server
Hi @sachin
All informations about indexing and how to start reindex you can find here - https://confluence.atlassian.com/adminjiraserver/search-indexing-938847710.html
About monitoring:
Seba
ok Sebastian thanks for your response .
We are using centos 7 in JIRA Server . Is it possible to check reindexing status via command line or any similar way ?
You can check status using curl command or you can read logs if you are have access to server.
You can use linux command to tail the logs for re-indexing process.
just make sure that you have access to Jira home folder
tail -f <jira home folder>/log/atlassian-jira.log | grep c.a.j.w.a.admin.index.IndexAdminImpl
Secondly, if you are on a data center you should run this command on the node server which you triggered the full-reindex process.
