I'm working as a qa tester.
I'm new to jira and to xray
how do I create test cases, test plans and test cycles
Hi @Asaf_Zilberberg,
you create them like other issues with the create button and just choose the right issue type.
I think, it will help if you have a look at the documentation here: https://confluence.xpand-it.com/display/XRAY/User+Guide
Thanks @Bastian Stehmann,
I created an issue type of test but didnt get to the screens and stage of actual writing the test cases with steps... how do I get too that?
I have Jira and Xray... do I need something else?
No, you do not need anything else. But make sure, that xray and it's issue types are enabled for the project where you try to do this. I think, there was an option in the project settings to do that.
But it is all very well described in the documentation.
Have a look here
https://confluence.xpand-it.com/display/XRAY/Custom+Fields+and+Screen+Configuration
and here
https://confluence.xpand-it.com/display/XRAY/Administration+Settings
for setup.
https://confluence.xpand-it.com/display/XRAY/Test
https://confluence.xpand-it.com/display/XRAY/Test+Set
https://confluence.xpand-it.com/display/XRAY/Test+Plan
https://confluence.xpand-it.com/display/XRAY/Test+Execution
All this links are just one or two clicks away from the link in my first post. I would really appreaciate it, if you just take a look there yourself.
Thanks... but on my view I don't have the part the test steps...
I just see issue type, summary and description...
what do I need to add to see the marked in the print screen section?
Hi ,
Did you read the link to customer fields and screens?
You will have to enable that field in your field configuration and add it to your screen.
