Dear Ian,
You can simply delete an issue when you are on the page of an Issue. Press ''More'' and ''Delete''.
You do need the required permissions to remove the issue though, if you do not have those.. you will not be able to delete it.
https://confluence.atlassian.com/adminjiraserver073/managing-project-permissions-861253293.html
Friendly Regards,
Jeremy Mooiman
Jeremy,
Thankyou for your feedback, however unfortunalty that option is not open to be there is no delete button. Is this only available as an administrator as i only have user priviledges.
Kindest Regards,
Ian
Dear Ian,
Then the following is going on here;
The project does not allow your role (user?) to delete issues. So unfortunately, you will have to ask someone in a role who is able to remove your issue to do so.
Delete issues
Permission to delete issues. Think carefully about which groups or project roles you assign this permission to; usually it will only be given to administrators. Note that deleting an issue will delete all of its comments and attachments, even if the user does not have the Delete Comments or Delete Attachments permissions. However, the Delete Issues permission does not include the ability to delete individual comments or attachments.
If you found my answers helpful, feel free to upvote.
Friendly Regards,
Jeremy
@Ian
And as a reminder;
I also commented on
i am supposed to be the scrum master on the project and i need to assume the role of the administrator - how do i obtain that?
this is a real pain that i simply cant delete an issue i created as a test to learn about your tool.
do i need to:
1 - ask someone at jira to do this for me, now and going forward?
2 - create an entire new project every time i make a mistake?
3 - get admin rights
please help.
