how to assign subtasks to a project role
Raju Adluru October 1, 2015
Hi Micha
Thanks for great plugin, we want to use it, how can i assign the subtasks to a project role?
Raj
Nic Brough -Adaptavist-
October 1, 2015
You cannot assign issues to a role, only users.
Russell Zera
JMWE allows you to assign an issue to a Project Role as a post-function on a workflow transition. It will assign it to the FIRST user in that role (If multiple members of that project role exist) or you can select the option to assign it to the LAST user that role as well (once again, if multiple members of that project role exist).
Micha Kops
October 7, 2015
@Raju Adluru I think adding this feature to the plugin would be a useful feature. I'll be commenting on updates in the following feature request in the project's issue tracker here - please feel free to comment and follow the feature request there:
https://bitbucket.org/hascode/jira-quick-subtasks/issues/182/set-watcher#comment-22320881
Raju Adluru October 7, 2015
Hi @Micha Kops
Can we add watchers to Subtasks while creating them.
