how to export issues more than 2000 in jira instances
DH20275693 August 9, 2022
while trying to export issues from jira instance to openjira I am getting error.jirainsatnce error i.png
Dave Mathijs
Hi @DH20275693 , the limit previously was 1000 results.
You need to split the issue search via a filter criteria into chunks lower than your limit, export twice and then merge the results again.
DH20275693 August 10, 2022
Can you help me how to limit the export  of issues
Dave Mathijs
Hi, can you share the current JQL of the filter results you would like to export?
How to take JQL of results
Dave Mathijs
Under Issues > Search for issues determine the criteria of issues you would like to export. Then switch to Advanced to see the JQL.
See also: Advanced searching
Venugopalan Anuja
October 10, 2024
@Dave Mathijs Hi Dave, I have the same problem. But I do not have any more filters to split and merge. This is what my JQL looks like- project = PCR AND issuetype = "Documentation Change" AND status in (Implemented) AND "PCR Context" = P6700 ORDER BY created DESC, priority ASC
How can I export the results then? My results are getting closer to 2k and I'm afraid I don't have anyone locally that has been able to resolve this issue. Pls help.
Tansu Akdeniz
Hi @DH20275693
In addition to @Dave Mathijs response, you can also check this KB. You will again need to merge the results.
