×I want to recieve notification when a particular custom field is enabled in JIRA .
How to configure that JIRA notification for any custom field
What to you mean by enabled ? Once the field is created ? is updated ? is added to a screen ?
i have a field called Cleanup , it is optional field ,so whenever it is selected , i want to send notification to a specific team DL
how to do so ?
That does not quite answer the question Mohamed asked, but it's a start.
I think you are saying that you want to send an email when someone updates a field on an issue, changing it from <empty> to <something>. Is that right?
Hi
So you will need to use automation or an another addon to send notification when the value change from empty to something else.
You can start by reading this documentation
https://confluence.atlassian.com/automation/get-started-with-jira-automation-993924596.html
