×I created a dashboard for my team but they only can view it. I want to give them acces to write on the dashboard and work it as if it were a repository.
Hi @Sol Alfaro,
Welcome to the community.
I don't get what you want to do. Do you want to give your team the ability to configure the dashboard, I.e. change gadgets or something like that?
Hi, thank you
Yes, I want to give them the access to configure the dashboard, add gadgets and change filters
Which version of Jira are you using. In the current version, you can add editors to the dashboard in its config.
I'm not sure with which version this feature has been delivered exactly, but if you can update to 7.13.x, it will be definitely there.
