how to pull status changes in transitions using vba?
Chai Teng Ong August 22, 2017
I would like to pull the date of status change in transition from Jira to Excel
Warren
August 23, 2017
Hi
It's your lucky day, because until a few months ago I used to use VBA for my REST calls, so I still have the code (I've now moved to C#). Remember in the encoding function to add your e-mail address and password, separated by a colon (:)
Public JiraService As MSXML2.XMLHTTP60
' *** Returns the issues as per the JQL query ***
Public Function GetIssues(query As String) As String
Dim json As Object
If JiraService Is Nothing Then Set JiraService = New MSXML2.XMLHTTP60
UserNameP = UserPassBase64
With JiraService
.Open "GET", query
.SetRequestHeader "Content-Type", "application/json"
.SetRequestHeader "Accept", "application/json"
If UserNameP = "NoAuth" Then
.SetRequestHeader "Authorization", "No Auth"
Else
.SetRequestHeader "Authorization: ", "Basic " & UserNameP
End If
.Send
If .Status = "401" Then
GetIssues = ""
Else
GetIssues = JiraService.ResponseText
End If
End With
End Function
' *** Encodes the Jira Username and Password ***
Public Function UserPassBase64() As String
Dim objXML As MSXML2.DOMDocument60
Dim objNode As MSXML2.IXMLDOMElement
Dim arrData() As Byte
Dim URL As String
UserNameP = "Jira_email:Jira_password"
arrData = StrConv(UserNameP, vbFromUnicode)
Set objXML = New MSXML2.DOMDocument60
Set objNode = objXML.createElement("b64")
objNode.DataType = "bin.base64"
objNode.nodeTypedValue = arrData
UserPassBase64 = objNode.Text
End Function
Chai Teng Ong August 23, 2017
But this is for login purpose only right?
What if now I need to pull the date on each status change from Jira transition to Excel? Like from Created > In Progress > In Review > Resolved > Closed.
Warren
August 23, 2017
Hi
This is generic code and any API call can be run through it. The query that you pass in to GetIssues is of the form :
"https://companyname.atlassian.net/rest..."
where after rest you can have any API call together with it's associated JQL
Yes, I have did that.
But now, I'm stuck on how to extract and get the data in transition part.
Besides, I have another problem, where there is a debug error in Excel VBA when I try to get the custom fields which the value=null.
Warren
August 23, 2017
For the transition, use something like :
status changed FROM Created TO "In Progress"
in your JQL bit - test it in Jira's Advanced issue editor.
For null values, use IIf and IsNull e.g.
estFrom = IIf(IsNull(histories(z)("items")(i)("fromString")), 0, histories(z)("items")(i)("fromString"))
For the null value problem, I tried with this
AR = IIf(IsNull(Json("fields")("customfield_10010")(1)("value")), 0, Json("fields")("customfield_10010")(1)("value"))
but still have the Run-time error '13': Type mismatch, if the value of the custom field is equal to null. While it's working fine if there is some value in that custom field.
For transition, it does give me the result of a list of issues when I search through Advance search in Jira. But how do I get the date changes?
where the json code for the custom field is as shown in the picture
Warren
August 25, 2017
I think what you need to do is
AR = IIf(IsNull(Json("fields")("customfield_10010")), 0, Json("fields")("customfield_10010")(1)("value"))
so the IsNull check looks at the highest level of the customfield - if it isn't null, then you can use the lower level value. With your code, you're testing the value of a non-existent field
Chai Teng Ong August 25, 2017
The same error still there with the code below,
Mei Ying Phuah August 24, 2017
Nic Brough -Adaptavist-
August 22, 2017
Your VBA will need to issue a REST call to get an issue.
See https://docs.atlassian.com/jira/REST/server/#api/2/issue-getIssue and look for the "changelog" section
Hi, can I have a sample of code in Excel VBA format?
August 22, 2017
Not from me I'm afraid, I don't do anything with BASIC and avoid spreadsheets as most of them are wrong.
