Hi @Ritesh Khatri ,
You can share your ideas at jira.atlassian.com, Atlassian Jira instance is for collecting suggestions and feature requests. If someone replies, you can ask for a call/meeting :)
Or if you want to report any issue or need any help, contact Atlassian support directly through https://support.atlassian.com/contact/#/
Just to double check. I know this is the way for Data Center products, but for Cloud they actually usually show this message, without the option to create a ticket.
Am I missing something?
Hi @Hans Polder _Devoteam_ / @Ritesh Khatri ,
Go to your cloud instance, in the main menu bar left corner, click on "?" --> Give feedback about jira. There you can fill the details and select "Yes, Atlassian teams can contact me...." option.
