how to rename plan in jira
RaviKanth.Bhandari
May 18, 2022
i have created a plan in jira and want to re-name it
Nathan Dorsey
April 9, 2024
It appears there are multiple ways to go about this depending on version, etc.
I did not see the option to do what Andy suggested, rather in our version on the left side of the interface about halfway down there is a gear icon labeled Plan Settings.  Press that and search for GENERAL.  Under that is Plan info.  Selecting Plan info opens a window that contains a box labeled Plan name.  You can change the plan's name here.
I hope this helps the people that could not find the method Andy described.
Chrystine January 17, 2025
This worked for me! Thanks @Nathan Dorsey
Andy Rusnak
May 19, 2022
Hi RaviKanth,
To rename a plan in Jira Server you should be able to select the name of the plan from the plan interface at the top which will launch an edit box.
So you would want to go to Plans > View Plans.  Then select the plan you want to rename. This will load the plan interface.  In the upper left you will see the plan name, if you select that name it will open an edit box and allow you to change the name. Once you have updated the name select the checkmark and the name will be saved.
Please let me know if I have misunderstood your request or if you have any additional questions related to this.
Best,
Andy
Brian Horton June 28, 2023
@Andy Rusnak How do I rename a Program in Plans? Example, I have several programs and under each program many epics....I need to modify one of the program names but unable to do that from the "plans" view.
Brian
@Andy Rusnak Well, that was simple enough :)
Changed the program (parent Link) name but now does not reflect in the parent link drop-down so I can change the epics to the new name.
