You can filter on the custom field to report on it, however there isn't a way to sum the total of all the fields unless you export to an excel spreadsheet and then add the total field after you export it. There may be a plugin that is available.
use what of 'each' You need to provide some more information.
@Joe Pitt i need to Browse all issues in a project to do the sum of custom field.
this custom field has different value in each issue. i woul like to get the total
Regards
