hello team
As i said i have original estimate 3h , remaining estimate 2h , now the worklog only show the unspecified work .
I do not understand the problem , i need help .
Regards
It's showing this because you have entered 3h for the original estimate and then either someone has logged an hour's work, or they have changed the remaining estimate.
I am not sure what you mean by "now the worklog only show the unspecified work . " - that sounds like you have an hour's work log, with a description of ".", is that right?
Nor do we - I can see you've got an estimate of 3h, with 2h remaining, but I don't understand the rest of the problem. Could you explain "now the worklog only show the unspecified work . "?
