i need add due date on issue subtask using jira rest api
Yasashree June 8, 2021
Currently i am using 'https://projects-lab.cdk.com/rest/api/latest/issue/' to create subtask but i am unable to create due date for it. I am able to see due date field on jira but i am unable to add it using rest api by passing payload.
Niranjan
June 8, 2021
Hi @Yasashree ,
Are you able to set the due date field via JIRA UI ? To set Due date on an issue, you need "schedule Issue" permission on the project. You may need to check for the permission.
i am able to add due date in UI
@Niranjan i am able to add due date in UI
Niranjan
June 8, 2021
@Yasashree - Try to pass the value like this
"duedate": "2021-06-09"
If it does not work, kindly share the complete restapi POST call
@Niranjan  where do i need to put this in payload
Niranjan
June 8, 2021
@Yasashree - Pass it like every other field. You can check this article .
Yasashree June 9, 2021
@Niranjan  it is working
{    "fields": {
    "project": {
               "key""TLRELEASE"
     "parent": {
                "key""TLRELEASE-6735"
     "summary""CHECK_Test",
     "description""add description",
     "duedate""2021-06-09",
      "issuetype": {
                       "name""Sub-task",
                        "subtask"true
     "assignee": {
           "name""akulay"
 "labels": [ "ReleaseManagement""CS"        ]    }}
Like Niranjan likes this
Niranjan
June 9, 2021
@Yasashree - Good to know. Kindly accept the answer so that the post will be marked as closed. Thanks
djohnson July 10, 2023
Hey @Niranjan
I am trying to set the due date for my subtask when it is created through the rest api. I am using the above format in my payload but still get a 400 error. Any advice?
Derek
