indexOf starting at a position
Steve Tedeschi
Trying to parse user provided content in a table - example
||Property||Value||
|prop1|Value 1|
|prop2|value 2|
eg
||Property||Value||
|Date|2025-02-08|
|Day|Saturday|
|Year|2025|
|Month|February|
|Day|8|
I can use the indexOf to find the property "cells" looking for a way to find the first pipe "|" after "|prop1|"... the first pipe after "|prop2|" etc.
Bill Sheboy
February 8, 2025
Hi @Steve Tedeschi
Where are you trying to do this?
For example, if this is with an automation rule you could try using the match() function with a regular expression:
https://confluence.atlassian.com/automation/jira-smart-values-text-fields-993924863.html#Jirasmartvaluestextfields-matchmatch()
Steve Tedeschi
Thanks for the suggestion - looks promising. Will give it a try and update here.
Steve Tedeschi
@Bill Sheboy Can you help with syntax to access the array elements? I thought I would add the array index in brackets (e.g., [0]), but am getting the following error:
Error rendering smart-values when executing this rule:
Failed to get value for issue.description.match(".*(|).*")[0]: {{issue.description.match(".*(|).*")[0]}}
Bill Sheboy
February 12, 2025
Hi @Steve Tedeschi
For accessing list elements in a rule, use the 0-based get() function:
{{issue.description.match(".*(|).*").get(0)}}
or use the first function to get the 0th one:
{{issue.description.match(".*(|).*").first}}
Wouldn't both of those just return the pipe character?
Steve Tedeschi
@Bill Sheboy - First and foremost thank you for pointing me in the right direction!
Q: Wouldn't both of those just return the pipe character?
A: Correct. I am looking for the contents within the table cells, which I am able to do by replacing match with split.
Updated Description (using single pipes for table headers)
|Property|Value|
|Date|2025-02-08|
|Day|Saturday|
|Year|2025|
|Month|February|
|Day|8|
Here's the output:
issue.description.split("|").get(0) = ' '
issue.description.split("|").get(1) = 'Property'
issue.description.split("|").get(2) = 'Value'
issue.description.split("|").get(3) = '
issue.description.split("|").get(4) = 'Date'
issue.description.split("|").get(5) = '2025-02-08'
issue.description.split("|").get(6) = '
issue.description.split("|").get(7) = 'Day'
issue.description.split("|").get(8) = 'Saturday'
issue.description.split("|").get(9) = '
issue.description.split("|").get(10) = 'Year'
 Not sure why the first array item is empty. Items 3, 6, and 9 are new line characters
Like Bill Sheboy likes this
Bill Sheboy
February 13, 2025
The first is probably null because the leading character is a delimiter (i.e., pipe).
And, newlines can be problematic for scenarios like this, more so when using match().  If they are causing trouble, perhaps replace them with another known / ignored delimiter.  I often use a double-tilde such as ~~ to get them out of the way, but replaceable back to newlines, as needed, later.
Just to confirm, do you have what you need now to parse the data?
Steve Tedeschi
Yes confirmed. Thanks again for pointing me in the right direction!
