I need to import thousands of test cases ,and I need to add many many components manually, it's so crazy. I want to create batch components or import those
Hi Jian,
I have to admit that I'm not very familiar with test case usage in Jira. This isn't a native functionality to Jira itself. Usually test cases are an additional function that is provided by a 3rd party plugin like testrails, or test case management.
However if I understand your question, these test cases are using multiple components in a Jira project. Have you seen our KB on How to bulk import Components into JIRA?
It provides a couple of different ways in which you can add these components to Jira, either via CSV imports, or even mentions using the REST API to create these.
I hope this helps.
Andy
