Hi
What i should set to get under this {{issue.issuelinks.outwardIssue.key}} link also?
and another question, how i should write that only one outward link is in e-mail not many if it has?
<a href="{{issue.url.customer}}">{{issue.key}}</a> <-- seems to be easy but in outwardlink?
Hi @Urmo
This seems to be a question about an automation rule. If so, please post images of your complete rule and the audit log details showing the execution. That may provide more context for the community to help. Thanks!
Regarding your questions...
Would you please clarify what you are trying to accomplish?
Those are smart value lists and so can return zero-to-many values. Let's say you wanted only the first one, you could use that reference, as shown here: https://confluence.atlassian.com/automation/jira-smart-values-lists-993924868.html
Hi
Idea is to collect issues from service management portal. Then some kind issues closed in SM project and clone into another project. Now i like to add new issue key link into e-mail what system sent to user.
Thanks for that rule image. I note two things to try:
After you edit this trigger issue's fields, add a Re-fetch action before you use the Clone action.
Next, if you want the email to contain the newly cloned issues information, you may refer to it using the smart value {{createdIssue}}
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-issues/#--createdIssue--
Hi
I did not use before clone Re-fetch issue data because there is nothing what clone issue should take over from orginal issue to new one.
Hi Urmo,
did you find a solutions for this?
Regards
Hi
I did not solve this problem this way. Only working solution for this moment was not create issue into new project but into same but change issue type and then all data did live and customer have same issue number and link.
Many thanks for your response.
