×Requirement example
1) Need to better understand reporting or, ideally, integration with excel.
2 )If we need to provide cash flow forecasts, we don’t have monthly or quarterly spend projections here. Could solve this via an excel integration?
Hi @MURUGESH S ,
If you are looking to send Jira data automatically, either in real-time when changes occur or on a set schedule, to Excel 365 without having to do manual exports each time, you can look at our add on Excel Integration for Jira that support this functionality.
The Mobility Team
Hi @MURUGESH S
You can find several options for exporting Jira data to Excel in this thread, if that is what you are looking for. Hope this helps.
sorry i am not getting the answer what i have looking it in automatically
@MURUGESH SUnfortunately, I am not aware of any apps that support your use case of automatically exporting to Excel in Cloud. But you should check the Atlassian Marketplace yourself, maybe you find something which suits your needs.
@MURUGESH S If you like the Better Excel Exporter app mentioned in that thread, and you want to generate those exports automatically, then the free Better Excel Automation app will add automation capabilities to the exporter.
Basically, it will integrate Excel exports to the standard Jira Cloud automation rules by making the standard REST API call to the Excel Automation API:
It is easier than it may look for the first sight, just check out the intro video!
(Discl. these apps are developed by our team.)
