I have a manual automation
I create an EPIC: TEST123
then run my manual automation, this then should create 3 tasks
Then: create a new: TASK "Task 1 Create your project"
For most recently created issue
then create a new: TASK "Task 2 create your part numbers"
and: create a new: TASK "Task 3 create your bill of materials"
This works. I now want my tasks to be linked.
Task 2 create your part numbers (LINK TO TASK 1)
Task 3 create your bill of materials (LINK TO TASK 1)
This is where the problem occurs. Instead I get:
Task 3 create your bill of materials (LINK TO TASK 2)
Even though Task 3 is still under the "For most recently created issue" it should create a link to TASK 1. I cannot get it to work
Hi Julia,
When you link the issues to "Most recently created issue", that is relative to the last issue created.
As you are branching to the first one, Task 1, you could change the link to "Current Issue" as that will refer to the "branched to" issue.
Thanks for the quick response!
For Task 2 I have "most recently created issue" and this correctly links me to Task 1
But I cannot figure out any setting that will link Task 3 to Task 1. I am wondering if in Task 1 I need to save its issue key to a variable, and then in Task 3 assign the link to the variable I created...but I have no idea how to do that or if that is even correct
I only have these 2 options for what my issue is linking to:
Thanks for that information; I am using Jira Cloud rather than Data Center and see something differently for that action.
Let's try this:
thank you again for the details. ok tried the {{issue.key}} but now TASK 3 has no linked issues
EPIC:
TASK1 (with correct link to TASK 2):
TASK 2 (correctly shows backward link to TASK 1):
TASK 3 (INCORRECTLY HAS NO LINKS):
That is curious...it states right there under the field in the action that smart values work, as does the documentation:
Please add a write to the audit log inside the branch with the following to check what the value is, then re-test to see if the issue is present:
branched to issue key: {{issue.key}} and first created issue: {{createdIssues.get(0).key}}
Please remove that text from the "more options...additional fields" fields area and instead add a Log Action to write that text to the audit log:
Thanks! That indicates either value should have worked for the linking.
Let's try this: remove the branch and directly link to that first created issue:
If that does not work, there are two other methods to try, with JSON and one-by-one branching.
Good day! Thank you very much for the help. The linked issue piece is working! Some additional questions:
1. Does this mean that I need to remove all branching?
2. I have a list of about 15 tasks that my complete automation runs, does this mean I need to keep track of the index for each one that I want to link to and adjust the {{createdIssues.get(X).key}} where X is the index of the task I want to link to.
3. Do I need to refetch issues?
Also, this did break the component inheritance.
WHAT I NEED:
WHAT I GET:
Answer: Correct, the branching is no longer needed. It only helped with the linking and that now works.
Answer: Yes, and this will get complicated / brittle very quickly for that many tasks. Additionally, you may need to add additional re-fetch actions to slow the rule down to make the linking successful.
Answer regarding the Component field copying...are you setting the Epic Link when the issue is created AND using "Copy from Epic" for the Components? Have you tested that approach?
If that does not work, a single branch could be used at the end to copy the Components or JSON could be attempted as each issue is created.
Thank you for the response.
1. I create my epic, assign my component "PCBA EPIC"
2. I then run my automation that checks for component "PCBA EPIC"
3. at which point my automation creates a bunch of standardized tasks for a PCBA board design grouped by the linking. I was originally going to use subtasks but cannot use those in different sprints, so I adjusted that to tasks with linking
4. you mentioned that it can become brittle...is there a better way to do this?
So is the trigger issue an Epic? If so that may simplify things a bit:
Regarding "brittle"...In my opinion, any rule this long (i.e., around 35 steps) which relies on a person to correctly select the indices in the get() could be difficult to maintain. There are other ways to do this, although not necessarily better, such as using multiple rules and custom fields to determine the linking.
One benefit of having everything in one rule is making it easier to see / correct problems when they happen.
Thank you for going through this. Yes making it easier to see/correct problems when they happen was part one of why I did one rule, also, having my team only have to run 1 rule and they get everything they need.
Clarification to your order (below with UNDERLINE AND BOLD)
With the complexities of this rule, I recommend not trying to also copy Components from the newly created issues. Instead add them again.
