jira restore problem when Migration server
wanwan
March 20, 2019
when I Migration server and use XML bakupfiles to restore the jira,it shows:
1、JiraImportTaskExecutionThread-1 ERROR root 1025x34x1 15p19z3 192.168.2.167 /secure/admin/XmlRestore.jspa [c.a.upgrade.core.DefaultUpgradeTaskFactoryProcessor] Upgrade task [host,buildNumber=77001] failed
java.lang.RuntimeException: Error running original upgrade task
2、Caused by: com.querydsl.core.QueryException: Caught SQLException for delete from clusteredjob
where clusteredjob.id not in (select max(jobs.id)
from (select preload.id, preload.job_id
from clusteredjob preload) as jobs
group by jobs.job_id)
at com.querydsl.sql.DefaultSQLExceptionTranslator.translate(DefaultSQLExceptionTranslator.java:50)
at com.querydsl.sql.dml.SQLDeleteClause.execute(SQLDeleteClause.java:222)
at com.atlassian.jira.upgrade.tasks.UpgradeTask_Build77001.lambda$doUpgrade$0(UpgradeTask_Build77001.java:54)
at com.atlassian.jira.database.DefaultQueryDslAccessor$1.lambda$executeQuery$0(DefaultQueryDslAccessor.java:85)
at com.atlassian.jira.database.DatabaseAccessorImpl.executeQuery(DatabaseAccessorImpl.java:68)
at com.atlassian.jira.database.DefaultQueryDslAccessor$1.executeQuery(DefaultQueryDslAccessor.java:84)
at com.atlassian.jira.upgrade.tasks.UpgradeTask_Build77001.doUpgrade(UpgradeTask_Build77001.java:53)
at com.atlassian.jira.upgrade.AbstractUpgradeTask.runUpgrade(AbstractUpgradeTask.java:61)
... 34 more
3、Caused by: java.sql.SQLException: You can't specify target table 'clusteredjob' for update in FROM clause
my server is centos 7.3,mysql:5.7.8-0.3,mysql-connect:mysql-connector-java-5.1.47-bin.jar,jira:7.9-->7.9
the XML backup zip file has: ├── activeobjects.xml ├── entities.xml
Andy Heinzer
March 22, 2019
Jira is failing to run this upgrade task due to a known bug in versions of MySQL between 5.7.0 and 5.7.17.  We track this from Jira's side in JRASERVER-67169
MySQL is tracking that bug in https://bugs.mysql.com/bug.php?id=79590
Technically this is not something Jira itself can fix.   Instead the solution here is to get to a database version that won't have this bug.
MySQL 5.7.18 and Later won't have this problem.  So I would recommend that you either update your database or migrate your Jira database to a version of Mysql 5.7.18 or higher OR to a different supported database type, such as postgresql.   This way you should then be able to complete this upgrade/migration of your data successfully.
I hope this helps.
Andy
Tom L August 15, 2022
Thanks, I will install the 5.7.18 version db to try again.
