×In the new jira cloud Issuefunction doesn't exist.
who can giv me a jql for issues in epic with certain label
I’m Charlotte, a support engineer at Appfire and I’m here to help you.
Unfortunately, using vanilla JQL, you’ll not be able to do it dynamically.
In the app where my team works, JQL Search Extensions for Jira, you can use this query to find issues in Epics with certain labels:
issue in childrenOfEpicsInQuery("labels = ABC")
Please contact our support if you have any other questions about this query.
We’ll be happy to help you! 😉
Hi David,
I can confirm to make issueFunction work in Jira Cloud, you need to use the Enhanced Search Page provided by ScriptRunner for Jira Cloud.
Once you have defined your filter on your enhanced search page, you can use it inside regular Jira in places like filters, boards and dashboards by following the steps below.
1. Save the filter and share it (This creates a copy of the filter as a standard Jira filter where we synchronise the list of issue keys returned by the enhanced search filter.)
2. Navigate to the area where you need to use this filter JQL and reference your filter in the JQL box using the JQL like below.
filter='NameOfHisSharedESFilter'
To help with searching for epics we provide the issuesInEpics() and parentsOf() and childnrenOf() JQL functions that will help to create the query that you require.
If you want just the enhanced search JQL functions, then we have the standalone Enhanced Search app that provides these at a smaller cost.
I hope this helps.
Kristian
Hi @David Verbeure,
Unfortunately, this is trickier than one might think; as a hierarchical query, it would really require some kind of join or subquery, which isn't available in plain Jira/JQL.
A few directions forward:
If you want to run your search "dynamically", without manually "stitching" two queries together, you'll need extra tooling:
Hope this helps,
Best,
Hannes
Just to expand on the last point, this is how this would look in the app that my team and I are working on, JXL for Jira. Put simply, you'd create a sheet with all issues that are potentially relevant to you, enable the default issue hierarchy (that's just one click), and then use JXL filtering capabilities to narrow down to the issues that you care about:
(I'm using labels here, but it would work the same way with any other field.)
Once you have your list of issues, you can work on these directly in JXL (much like you'd do in e.g. Excel or Google Sheets), trigger various operations in Jira, or export them for further processing.
Any questions just let me know!
Hi @David Verbeure You can try the below JQL.
parent = ABC-1 AND label = XYZ
Here ABC-1 is the Epic issue who is parent of all the issues in that Epic and label name is XYZ
Please try and let me know if you get what you looking for.
Sagar
You can start your journey here
Do you need to search all EPIC with a certain label?
issuetype = Epic and labels in (label2)
the labels in will allow you set to search for more than one label. only one label use =.
Regards
