Hi, I'm having a problem with the filter that allows me to find tickets with the following "epic link
a ticket (xx-x).
The filter works well for the tickets but not well for those of another project.
For example: "epic link"= SUPP-1138 returns all tickets whose parent is the ticket (supp-1138).
Whereas "epic link"= ISCF-21097 does not return all tickets whose parent link is the ticket (iscf-21097).
Do you have any ideas about this malfunction?
Hello @Ulrich Kone
Not quite sure but I think that something might be messed up with relations. Did you maybe tried Integrity Checker?
https://confluence.atlassian.com/adminjiraserver/using-the-database-integrity-checker-938847667.html
Hello @Mirek
Thank you for your answer
I found the solution
I think something went odd preforming the bulk change so I re-index the project and the filter started to show properly
