Hello, I have a project to create on Jira, it's a kanban board where tickets from other projects will be classified according to the status, do you think it's possible to link tickets from several projects to a single project?
Hi @medjouti yes it is fully possible to have tickets from multiple projects show up in a board. Yes it is possible to link tickets from other projects. I am curious about your use case though, what is it you are trying to achieve?
Hello @medjouti
A "Project" is a container for issues.
A "board" is a way to view and manipulate the issues.
Boards are based on filters. If you want to show issues from multiple projects on a board you create a board based on the multiple projects (if you want all the issues in the projects) or based on a saved filter.
Why do you want to create another project with its own issues and link those the the issues in the other projects? What problem are you trying to solve with that?
Hello! can you please tell me how I can create this Kanban board please? and how can I automatise that? because we want to have an automatic updates.
The probleme I am trying to solve, the probleme of not having an overiew of our advanement on every project.
You can find that information in this product guide document:
https://confluence.atlassian.com/jirasoftwareserver/creating-a-board-938845220.html
