looking for a solution in downloading a Jira attachment
Adrian Jordan
August 16, 2021
I was originally using Jenkins plugin (Jenkins JIRA Pipeline Steps) to integrate Jenkins with Jira.  Unfortunately, I am unable to successfully download the attachment(s) to my Jenkins worker node.  Debugging this further, I attempted to use curl to GET the attachment:  curl -L -O -k -u 'adrianj@ibm.com:<myToken' -X GET http://<myhost>/secure/attachment/3454761/test.txt. The file downloads, but the contents of the file is invalid and reference a 403 forbidden message:
<body id="jira" class="aui-layout aui-style-default page-type-message " data-version="8.13.9" >
    <div class="aui-page-panel" ><div class="aui-page-panel-inner">
            <main role="main" id="main" class="aui-page-panel-content" >
                    <div class="aui-page-header" ><div class="aui-page-header-inner">
                            <div class="aui-page-header-main" >
                                    <h1>Forbidden (403)</h1>
                                </div>
                        </div></div>
                    <div class="aui-message aui-message-warning warning">
                            <p>Encountered a <code>&quot;403 - Forbidden&quot;</code> error while loading this page.</p>
                            <p>Basic Auth with password is disabled by the API Token Authentication app</p>
                            <p><a href="/secure/MyJiraHome.jspa">Go to Jira home</a></p>
                        </div>
                </main>
        </div></div>
</body>
Are there in proven solutions in place to download Jira attachments?
Nir Haimov
Hi @Adrian Jordan
You got 403 and it says to you:
Means you have authentication problem
Adrian Jordan
August 17, 2021
Thanks @Nir Haimov .  Yes I saw that, which has led me down the path of using cookies.  I have a solution in curl, by creating the cookie:
curl -c /path/to/some/folder/cookie-jar.txt -u username:apitoken https://<jira-url>/rest/api/2/issue/<issueIdOrKey>?fields=attachment
and then using it
curl -b /path/to/some/folder/cookie-jar.txt "https://<jira-url>/secure/attachment/10100/portallog.jpg" --output /path/to/some/folder/portallog.jpg
Source of reference:  https://wiki.resolution.de/doc/api-token-authentication/latest/user-guide/knowledge-base/using-api-tokens-to-download-attachments
Nir Haimov
So all is good?
You managed to achieve your final goal? :)
