Can you help me please it's my first question in the web ? my client went migrate login for all user in external ldap to internal jira database and change user name by id number,
so for the first step it's easy but the second i modified 3 tables (cwd_user,cwd_memembership,cwd_user_attributes) but there are a lot of other associeted database for user name (issue, ...). are there any other solutions plugins , ... please Help ?
You shouldn't do it directly in the DB, take a look at solutions like: https://community.atlassian.com/t5/Jira-questions/How-to-bulk-rename-username/qaq-p/216275
thank you very very much Boris,
if I change the login of user to ID number, will I have the same password?
Best regards
It will not change the password.
