×I am using below code to create the ticket in Jira .
but i am not able to pass user name to setAssigneeId(12345) in below code getting not such property exception
import com.atlassian.jira.issue.context.IssueContext
import com.atlassian.jira.issue.context.IssueContextImpl
import com.atlassian.jira.issue.fields.config.manager.PrioritySchemeManager
// the project key under which the issue will get created
final projectKey = 'TEST'
// the issue type for the new issue
final issueTypeName = 'Bug'
// user with that user key will be the reporter of the issue
final reporterKey = 'auser'
// the summary of the new issue
final summary = 'Groovy Friday'
// the priority of the new issue
final priorityName = 'Major'
def issueService = ComponentAccessor.issueService
def constantsManager = ComponentAccessor.constantsManager
def loggedInUser = ComponentAccessor.jiraAuthenticationContext.loggedInUser
def prioritySchemeManager = ComponentAccessor.getComponent(PrioritySchemeManager)
def project = ComponentAccessor.projectManager.getProjectObjByKey(projectKey)
assert project : "Could not find project with key $projectKey"
def issueType = constantsManager.allIssueTypeObjects.findByName(issueTypeName)
assert issueType : "Could not find issue type with name $issueTypeName"
// if we cannot find user with the specified key or this is null, then set as a reporter the logged in user
def reporter = ComponentAccessor.userManager.getUserByKey(reporterKey) ?: loggedInUser
// if we cannot find the priority with the given name or if this is null, then set the default priority
def issueContext = new IssueContextImpl(project, issueType) as IssueContext
def priorityId = constantsManager.priorities.findByName(priorityName)?.id ?: prioritySchemeManager.getDefaultOption(issueContext)
def issueInputParameters = issueService.newIssueInputParameters().with {
setProjectId(project.id)
setIssueTypeId(issueType.id)
setReporterId(reporter.name)
setSummary(summary)
setPriorityId(priorityId)
def validationResult = issueService.validateCreate(loggedInUser, issueInputParameters)
assert validationResult.valid : validationResult.errorCollection
def result = issueService.create(loggedInUser, validationResult)
assert result.valid : result.errorCollection
Hi @Pravin Your Code is correct , add three lines to set Assignee :-
final projectKey = 'VY'
final reporterKey = 'vikrant-yadav2'
//assignee
final assigneekey = 'vikrant-yadav2'
def assignee = ComponentAccessor.userManager.getUserByKey(assigneekey) ?: loggedInUser
setSummary(summary)
setAssigneeId(assignee.name)
Hope it works for you.
Thank you for your reply .
but unfortunately getting below error .
groovy.lang.MissingPropertyException: No such property: userManager for class: Script323 at Script323.run(Script323.groovy:11)
Thanks ,
Pravin
Add :-
import com.atlassian.jira.user.util.UserManager
thanks
