On issue (<> epic) creation in a specific workflow I would like to set the project/customer value to the project/customer of the parent epic. so that when I create an issue in an epic, all issues inherit the project/customer information from the epic.
I succeeded to configure to set the project/customer to a specific value, but I don't see how to get the value from a parent element. (note that when you create an epic, project/customer is required and you can pick out from a list)
I tried by entering a smart value instead of a specific value (for ex. {{issue.epic.customfield_10056}} supposed to return the prj/customer of the parent epic - or {{issue.epic.Project / Customer}}) but no value is set.
Smart values are probably not meant for that. But how can I define the value in my post function?
Hi Geneviève - Welcome to the Atlassian Community!
Can you share the rule that you have so far?
I first had to make the Project/customer field (or customfield_10056) visible for the type of issue. (we don't need to view it, it was enough to set the value in the background but it seems Jira won't set a value if it is not visible)
Adding a post function to set the Project / customer to value "customer X" works.
But I want to inherit the Project / customer from the parent epic of the issue. I tried like this, but it has no effect. (after publishing my workflow). {{issue.epic.customfield_10056}} did not work either, but smart values are probably not meant to be used here. What else could I use?
putting the post function before the create (as help seems to indicate you need to do for custom fields) or lower in the sequence does not help
Sorry, I was under the impression that you were using Automation For Jira. I am not sure you will be able to do with post functions without using an add-on like JMWE.
But you would also do this with Automation For Jira which is now a free tool. See this for more information:
There are two types of automation:
Automation Basics: https://www.atlassian.com/software/jira/guides/expand-jira/automation
You can do this via global rules to apply to all projects also. You'll need to be a Jira Admin/Site Admin, go to Jira Settings > System > Automation Rules (left-hand menu).
For more on using Automation For Jira see these help pages.
Hi John, thanks for this input. I could set up an automation rule to do the trick :-)
