I am not sure if my configuration is correct. I want to associate a the field configuration scheme with 2 projects. Where should I configure it? I would like to select the "NCRs".
Thanks!
Use the use a different scheme option to change the current field configuration to a new one.
Thank you! I was not able to see that button!!!!!!!
You are welcome!
