project lead able to Adding/modifying fields in JIRA project??
Raju Anumula April 25, 2018
As far as i am aware it is not possible,if JIRA Version 7.4 is going to solve this???
Thanking you advance,
Bhoopal
2 accepted
Tarun Sapra
Hello @Raju Anumula
Project admins can add the fields in screens in their JIRA projects from 7.4 onwards but under these conditions
  • The screen must not be a default system screen.
  • The screen must not be shared with any other projects, or used as a transition screen in workflows.
  • The project admin can add, remove and rearrange system fields.
  • The project admin can add, remove and rearrange existing custom fields, but they cannot create custom fields.
Thanks a lot Tarun.
Alexey Matveev
April 25, 2018
In Jira 7.4 a project administrator will be able to change screens, used in the project under the following conditions:
- The screen must not be a default system screen.
- The screen must not be shared with any other projects, or used as a transition screen in workflows.
- The project admin can add, remove and rearrange system fields.
- The project admin can add, remove and rearrange existing custom fields, but they cannot create custom fields.
Thanks a lot Alexey.
