Hi!
I would like to inquire on how can check as to why when we hover our mouse, this "Create Issue" for sub-task in active sprint only shows in one of the columns and not on the other columns.
This is a company managed project and using scrum board.
Is this by design?
@Sherwin Soriano can you refer the doc shared by Derek the explaination is good if it helps to solve your query
Thanks for Reaching out to the community,can you please check the Board configuration of the Active sprints whether the child issues/Timeline is enabled or not.
Hope this helps
@Sherwin Soriano can you check this?
@Sherwin Soriano have you checked the configuration which i shared the screenshots
The "Create Issue" button is visible depending on your workflow configuration.
It appears only in columns mapped to:
Best Regards,
@Seifallah Bellassoued where do I check this one? I checked our workflow configuration, there is nothing in there about mapping and create issue button.
As per the shared screen, only columns mapped with Done status will not have "Create Issue" button except if you have conditions configured in the workflow.
