"Issue Links" section visible without links.
Paweł Jakimiak
Is there a way to set section "Issue Links" visible, even when there are no issue links?
Mauricio Karas
August 15, 2018
Hello, Paweł. Thanks for reaching out to the Atlassian Community.
Natively in Jira, there's no way to achieve this. The issue link div is not even created when there are no linked issues, this works for other section such as subtasks.
I think the only way to do this is by using Javascript through the announcement banner or a Tampermonkey script. You could insert a div equal to the actual one, but without any issues, then make some logic to check if there are linked issues or not.
Can you tell us a little more the general context of what you are trying to do? I thinking that maybe we can find other alternatives.
Maurício Karas
Paweł Jakimiak
Thanks for the reply and sorry for the delay. I know the way with announcement banner but I wanted to avoid this way.
By constant visibility this section I would have simple access to "+" button from "View" screen and I would not have to click on "More" and next "Link" button from top menu.
