This is the error I am getting when I am trying to create a project.
"errorMessages": [],
"errors": {
"project": "project is required"
code That I have used.
# This code sample uses the 'requests' library:# http://docs.python-requests.orgimport requestsfrom requests.auth import HTTPBasicAuthimport json
url = "https://rasateam.atlassian.net/rest/api/3/issue/"
auth = HTTPBasicAuth("<MYUSERID>", "<APITOKEN>")
headers = { "Accept": "application/json", "Content-Type": "application/json"}
payload = json.dumps( { "update": {}, "fields": { "summary": "Creating first ticket from API" #"parent": { # "key": "RASA" }, "issuetype": { "id": "10000" }, "components": [ { "id": "10000" } ], #"customfield_20000": None, #"customfield_40000": None, #"customfield_70000": None, "project": { "id": "10000", "key": "RASA", "name": "RASASLACKBOT", "projectTypeKey": "software", "self": "https://rasateam.atlassian.net/rest/api/3/project/10000", #"simplified": false }, "description": None, "reporter": { "id": "5f362439fdc3f5003f7fd882" }, "fixVersions": [], #"customfield_10000": "{}", "priority": { "id": "3" }, "labels": [ "bugfix", "blitz_test" ], #"timetracking": { # "remainingEstimate": "5", #"originalEstimate": "10" #}, #"customfield_30000": None, #"customfield_80000": None, #"security": None, #"environment": { # "type": "doc", #"version": 1, #"content": [ # { # "type": "paragraph", # "content": [ # { # "text": "UAT", # "type": "text" #} #] #} #] #}, #"versions": [ #{ #"id": "10000" # } # ], #"duedate": "2019-05-11", #"customfield_60000": "jira-software-users", #"customfield_50000": { # "type": "doc", #"version": 1, #"content": [ # { # "type": "paragraph", # "content": [ # { # "text": "Could impact day-to-day work.", # "type": "text" #} #] #} #] #}, "assignee": { "id": "5b109f2e9729b51b54dc274d" } } )
response = requests.request( "POST", url, data=payload, headers=headers, auth=auth)
print(json.dumps(json.loads(response.text), sort_keys=True, indent=4, separators=(",", ": ")))
Was troubleshooting a similar issue, and ran across a different root cause.
This ""project":"project is required" response comes not only when the project isn't in the json body, but also when the key you pass for the project doesn't exist.
Wish it would throw a separate message for "project key not found", but not the end of the world.
Hi @Prince Nyeche I am also getting 400 bad request Project is required error while trying to create issue from postman
Could you please help me to resolve this issue, attaching here payload and error screenshot:
Payload :
I don't think you're connecting to the Project API hence such error. you should use in the url variable.
Then specify the fields you want available during creation in your json payload. A Python example is shown on the developers doc here
Thanks for your response.
I wanted to create an issue in the Project, Here where I am facing the issue.
So as per your suggestion first you want me to connect to the project and there you wanted me to create an issue ?
As I am able to retrieve the Project and Issue details but unable to create a project.
Can you please elaborate a bit how we can create an issue in the required project.
Thanks in advance !!
If you simply want to create an issue, use the create issue API to do that, in your request payload that's where you specify the project to connect to. Creating Issues or Projects are separate APIs, so if you want to do either use the designated API to achieve your aim.
Thanks Prince.
The API code which mentioned above and causing the error is for the Create issue API.
If you can please have a look into my code and check which required details I am missing in the mentioned python code Because it is causing this error.
"errors": {
Python code :
I have provided my credentials for this.
<MYUSERID>
<APITOKEN>
Please help me with which details I am missing in it.
Do you have a Project with id:10000 on your Instance? you might want to check the Id of the project you're trying to create this issue on.
@Prince NyecheYes Prince, It is the project Id : 10000 on my instance. and when I am trying to get to details I am able to get details of issue and project but unable to create project or Issue.
Please help me that might I am missing any fields or anything as I set the "customfield_N0000": None custom filed none and Initially it thrown that I am not suppose to set that ..can you please suggest me how what are all the fields required for creating the issue. Will take that as reference and check with my case. Thanks!! Please check the above code and let me know . Thanks in advance!!
So I examined the json and it seems that the way you nested it was wrong. all those other fields should be nested inside of the "field": { } element. That's why that error was occuring. I cleaned the code up a bit for you. Please give it a try.
import requests
import json
def main():
url = "https://<yourinstance>.atlassian.net/rest/api/3/issue/"
auth = HTTPBasicAuth("<emailaddress>", "<apitoken>")
headers = {"Content-Type": "application/json"}
payload = {
"update": {
"fields": {
"summary": "Creating first ticket from API ",
"project": {
"id": "10016"
"issuetype": {
"id": "10004"
"reporter": {
"id": "5d2c28bd9dshdsddf9f"
"fixVersions": [
"priority": {
"id": "3"
"labels": [
"bugfix",
"blitz_test"
"assignee": {
"id": "5ab519dshdshdshdbb2b2"
response = requests.post(url, auth=auth, json=payload, headers=headers)
data = json.loads(response.content)
print(data)
if __name__ == "__main__":
main()
Yes @Prince Nyeche Its working fine now Thank you so much!!
Hi @Prince Nyeche Its working fine now Thank you so much!!
But Here I can able to create and delete the Issues and get details about the issue in a project. But I am facing issue with creating a project and editing the issue through API.
Can you please suggest codes for that as well ?? If you don't mine sorry for bothering you much!!
Hey @Veeranjaneyulu Kureti Are you using some form of SDK or Library to do this, or you're simply calling different script at a time. Can you post the sample code you're using so far for project creation and editing the issue and any errors you've gotten so far?
Hi @Prince Nyeche Thanks for your reply.
Issue with commenting in the JIRA ISSUE :
Error :
PS C:\Users\VeeranjaneyuluKureti\RASA_VEERU> python Comment_JIRA.py
"errors": {
"commentLevel": "You are currently not a member of the project role: Administrators."
code :
url = "https://ID.atlassian.net/rest/api/3/issue/SLAC-4/comment"
auth = HTTPBasicAuth(ID, TOKEN)
payload = json.dumps( { "visibility": { "type": "role", "value": "Administrators" }, "body": { "type": "doc", "version": 1, "content": [ { "type": "paragraph", "content": [ { "text": "Lorem ipsum dolor sit amet, consectetur adipiscing elit. Pellentesque eget venenatis elit. Duis eu justo eget augue iaculis fermentum. Sed semper quam laoreet nisi egestas at posuere augue semper.", "type": "text" } ] } ] }} )
Issue : EDITING ISSUE
ERROR :
PS C:\Users\VeeranjaneyuluKureti\RASA_VEERU> python Edit_issue.py
Traceback (most recent call last):
File "Edit_issue.py", line 76, in <module>
main()
File "Edit_issue.py", line 70, in main
response = requests.post("PUT",url, auth=auth, json=payload, headers=headers)
File "C:\Users\VeeranjaneyuluKureti\AppData\Local\Programs\Python\Python37\lib\site-packages\requests\api.py", line 119, in post
return request('post', url, data=data, json=json, **kwargs)
File "C:\Users\VeeranjaneyuluKureti\AppData\Local\Programs\Python\Python37\lib\site-packages\requests\api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "C:\Users\VeeranjaneyuluKureti\AppData\Local\Programs\Python\Python37\lib\site-packages\requests\sessions.py", line 516, in request
prep = self.prepare_request(req)
File "C:\Users\VeeranjaneyuluKureti\AppData\Local\Programs\Python\Python37\lib\site-packages\requests\sessions.py", line 459, in prepare_request
hooks=merge_hooks(request.hooks, self.hooks),
File "C:\Users\VeeranjaneyuluKureti\AppData\Local\Programs\Python\Python37\lib\site-packages\requests\models.py", line 314, in prepare
self.prepare_url(url, params)
File "C:\Users\VeeranjaneyuluKureti\AppData\Local\Programs\Python\Python37\lib\site-packages\requests\models.py", line 388, in prepare_url
raise MissingSchema(error)
requests.exceptions.MissingSchema: Invalid URL 'PUT': No schema supplied. Perhaps you meant http://PUT?
CODE :
import requestsimport jsonfrom requests.auth import HTTPBasicAuth
def main(): url = "https://ID.atlassian.net/rest/api/3/issue/" auth = HTTPBasicAuth("ID", "TOKEN") headers = {"Content-Type": "application/json"}
payload = { "update": { "summary": [ { "set": "Bug in business logic" } ], "components": [ { "set": "" } ], "timetracking": [ { "edit": { "remainingEstimate": "4d", "originalEstimate": "1w 1d" } } ], "labels": [ { "add": "triaged" }, { "remove": "blocker" } ]
}, "fields": { "summary": "Creating second ticket from API ", "project": { "id": "10000" },
"issuetype": { "id": "10001" }, "description": None, "reporter": { "id": "5f4786a7347294003e78e33d" }, "fixVersions": [
], "priority": { "id": "3" }, "labels": [ "bugfix", "blitz_test" ], "assignee": { "id": "5f362439fdc3f5003f7fd882" } } }
response = requests.post("PUT",url, auth=auth, json=payload, headers=headers) data = json.loads(response.content) print(data)
if __name__ == "__main__": main()
ISSUE : CREATING A PROJECT.
ERROR :
PS C:\Users\VeeranjaneyuluKureti\RASA_VEERU> python creating_project.py
"errorMessages": [
"Can not deserialize instance of java.lang.String out of START_OBJECT token\n at [Source: org.apache.catalina.connector.CoyoteInputStream@7406b7a0; line: 1, column: 46] (through reference chain: com.atlassian.jira.rest.v2.issue.project.ProjectInputBean[\"lead\"])"
CODE :
url = "https://ID.atlassian.net/rest/api/3/project"
payload = json.dumps( { #"notificationScheme": 10021, "description": "Example Project description", "lead": { "Id": "5f4786a7347294003e78e33d" }, #"url": "https://slackjira2020.atlassian.net/PROJAPI", "projectTemplateKey": "com.pyxis.greenhopper.jira:gh-simplified-agility-scrum", #"avatarId": 10318, #"issueSecurityScheme": 10001, "name": "PROJECT_API", #"permissionScheme": 10011, "assigneeType": "PROJECT_LEAD", "projectTypeKey": "software", "key": "PROJAPI", #"categoryId": 10120} )
Please help me out of this three codes which I am facing an issue. Thanks in advance!!
Basically, i looked at the json and it seems that you're not properly formatting it and using wrong methods in the request. There are 3 things you need to be aware of here
Just wanted to give you a baseline of how you could go about this, since you will be calling "GET", "PUT", "POST". it's better to have a method for this and pass the url and payload at will. I created this script to show you an example of how it would look.
Furthermore, for Edit issue, you should take a look at the fields from this endpoint /rest/api/3/field grab the field id if you want to PUT to a custom field. I wrote the example of some common field with how their payload should look like.
import requests
import json
EMAIL = "<email>"
TOKEN = "<apitoken>"
URL = "https://<your-instance>.atlassian.net/rest/api/3/myself"
class Jira:
def __init__(self):
self.url = URL
self.auth = HTTPBasicAuth(EMAIL, TOKEN)
self.headers = {"Content-Type": "application/json"}
def __str__(self):
self.login = self.get_only()
self.accept = "Login Accepted..."
self.reject = "Login Failed..."
if self.login.status_code == 200:
return self.accept
else:
return self.reject
def get_only(self):
response = requests.get(self.url, auth=self.auth, headers=self.headers)
return response
def get_payload(self, url, payload):
response = requests.get(url, auth=self.auth, json=payload, headers=self.headers)
return data
def post_payload(self, url, payload):
response = requests.post(url, auth=self.auth, json=payload, headers=self.headers)
return data
def put_payload(self, url, payload):
response = requests.put(url, auth=self.auth, json=payload, headers=self.headers)
if response.status_code == 204:
success = "Data has been Posted..."
return success
else:
fail = "Failure Posting Data..."
return fail
def main():
issue = Jira()
# print out if api connection is successful or not
print(issue)
# define new urls and payload in main() and call the request by using
# the method in Jira Class
# issue comment example
url = "https://<your-instance>.atlassian.net/rest/api/3/issue/AT2-466/comment"
payload = (
"visibility": {
"type": "role",
"body": {
"type": "doc",
"version": 1,
"content": [
"content": [
"text": "Test restoreLorem ipsum dolor sit amet, consectetur adipiscing elit. "
"Pellentesque eget venenatis elit. "
"Duis eu justo eget augue iaculis fermentum. Sed semper quam "
"laoreet nisi egestas at "
"posuere augue semper.",
"type": "text"
issue.comment = issue.post_payload(url, payload)
# print(issue.comment)
# create a project example
url = "https://<your-instance>.atlassian.net/rest/api/3/project"
payload = (
"notificationScheme": 10000,
"description": "Community API Creation",
"leadAccountId": "5ab5195e0dcb662ab2b2",
"url": "https://atlassian.com",
"projectTemplateKey": "com.pyxis.greenhopper.jira:gh-simplified-scrum-classic",
"avatarId": 10401,
"name": "Community API Creation Project",
"permissionScheme": 10000,
"key": "CACP",
"categoryId": 10000
issue.project = issue.post_payload(url, payload=payload)
# print(issue.project)
# edit issue example
url = "https://<your-instance>.atlassian.net/rest/api/3/issue/AT2-364"
payload = \
# to see the field id goto /rest/api/3/field
# custom fields needs to use their custom id prior to put or post
"fields":
# custom field type single options value
"customfield_10087":
"value": "UK",
# String value - custom field type Text Field
"customfield_10095": "RH011",
# user value - custom field type Single User picker
"customfield_10120":
"accountId": "557058:5bced99d8bd8d"
"priority": {
"id": "3"
# system fields labels - placed in a list
"labels": [
"space",
"red"
issue.edit = issue.put_payload(url, payload)
print(issue.edit)
main()
Hope you can use this examples for your other type of request; as what you can do is just define the url and payload properly and the script can basically get the response.
